CUCM 9.1.2.12901-3 VMWare Tools Upgrade Never Ends
Joey De Wiele
I recently upgraded to 9.1.2.12901-3 and after, when I attempted to upgrade VMware Tools, the VMware Tools upgrade never ended and fails.
Is there some documentation on this out there somewhere?
Joey
Hi Joey.
You are probably falling into this bug CSCus40939
The only workaround suggested is to reboot the VM or upgrade CUCM to a later release.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Joey.
Carlo
Joey De Wiele
Thanks.
Rebooting the VM got things working properly but the VMware tools install failed.
This isn't so important and we'll worry about VMware tools when we upgrade to 10.x.
Joey
