Discussion Jabber on Notebooks and Cisco 2901 gateway
ice.polar
At work we now have Cisco Jabber clients on notebooks. Internal connections are now possible, allthought with great latency because the central "master" resides a thousand kilometers thru europe away behind a VPN-connection. As a country subsidiary a local cisco 2901 should connect to the telephony  as a gateway...
- How is the general architecture of cisco collaboration?
- Is it correct to look at our cisco 2901 like a local domain-controller in windows-network?
Gordon Ross
Level 9
Level 9
The 2900 can act as a local IP telephony system (Either as CallManager Express, or a backup system as SRST) But Jabber clients currently requires a full-blown server for users to connect to.
GTG
Please rate all helpful posts.
Thx for the answer. To figure it out more clear on a top-level:
We are sitting in the south of europe and our master resides up in North. Using Jabber clients on notebooks a telephony-call to customers in our country will go throught vpn-tunnel up north to u-turn and  come down to our cisco2901 which is connected to legacy telephony-(ISDN-)wires and finally to customers...
Is this a recommended architecture?
