HELP IN Mediasense upgrade
Zaher Juha
Dears,
I'm About to upgrade our Mediasense server from 9.X to 10.X
I need your help guys in this like the Refresh Upgrade COP file how can i get it also is it the same sequence as upgrading Normal CUCM
Also Can i rollback if anything happened
THanks guys in advance
Cheers
Manish Gogna
Hi Zaher,
The procedure to upgrade Mediasense to version 10.0 is explained in the following link in detail
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/mediasense/10/user_guide/CUMS_BK_MCD100EE_00_ms-user-guide-10_chapter_010.html#CUMS_TK_U35D62AF_00
Manish
Thanks Manish,
The upgrade has been done successfully the the CM Administration shows 10.5 but the Search and Play shows 9.1 ??? any explination for that
