CUCM and CME - internal calls
Janos.nagy
Hey guys
We have 2 problems with two of our Callmanagers.
We are using one CME (running on a Cisco 2911) and one Cisco Unified Communications Manager Business Edition, both are connected via IP.
1. problem CME to CUCM
The problem is when someone from the CME calles an attendant on the CUCM side,
the caller transmitted this name and hole number, but I only want to see the internal extension.
Config CME:
telephony-service
max-ephones 50
max-dn 100
ip source-address 10.37.50.20 port 2000
timeouts interdigit 4
system message Jesta Digital - New York Office
cnf-file location flash:
cnf-file perphone
load 7942 SCCP42.8-4-2S.LOADS
load 7962 SCCP42.8-4-2S.LOADS
time-zone 13
dialplan-pattern 1 21289662.. extension-length 4 extension-pattern 62..
dial-peer voice 5000 voip
description NY to BER
destination-pattern 5...
session target ipv4:10.35.4.22
Config CUCM see screenshot in the attachment
Question:
At the moment on the side of the CUCM, call form the CME are shown this way 212896XXXX but I want it this way XXXX.
Is there any possibility to strip the number, or another solution?
2. problem CUCM to CME
If someone from the CUCM calles an attendant on the CME side, only the internal number are transmitted.
Is there any possibility to transmit the name and the number from the CUCM to the CME?
kusatija
Hi Janos,
For the 2nd part try checking the Display IE Delivery checkbox.. on the gateway..
for the 1st question please provide the running config from the CME...
Kunal
Thanks for the fast response, I will the check the function Display IE Delivery.
And here is the running config from the CME
version 15.0
hostname XXX
boot-start-marker
boot-end-marker
card type t1 0 0
logging userinfo
no logging console
enable secret 5 $1$mynw$/BpbDYU0JvDri2hG1swQ./
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login no_tacacs local
aaa authentication enable default group tacacs+ enable
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 15 default
action-type stop-only
group tacacs+
aaa accounting network default
group tacacs+
aaa accounting connection default
group tacacs+
aaa accounting system default
group tacacs+
aaa session-id common
clock timezone EST -5
clock summer-time
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip domain name
isdn switch-type primary-qsig
crypto pki certificate chain TP-self-signed-3557788374
certificate self-signed 01
  30820259 308201C2 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33353537 37383833 3734301E 170D3130 30343330 31343336
  33395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 35353737
  38383337 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B201 C2B85478 7A9D6E51 A20C902E 9913821E 9ACFD1C8 5B84A8DD 9C1F60AE
  2AEBF80F EE08CD0C 3A957B80 D13A7FE4 BD9D521A FD054BED 81585CFD E61F902B
  956A8089 8BBCFF8E 4BDDECC8 34695A36 8D9BEC1A B19E8D6C C0C107CF 98E46476
  19733E33 3E28617E 537A169A A130B72F 8F7A9E75 43DBC55A 8AD3E95B DD2FC609
  86410203 010001A3 8180307E 300F0603 551D1301 01FF0405 30030101 FF302B06
  03551D11 04243022 82207465 6C636F31 2E636F72 702D626F 2E6E7963 2E666F78
  6D6F6269 6C652E63 6F6D301F 0603551D 23041830 16801432 EBFF43EE 5EC1AA7F
  B408AAF0 D428F1B9 08F53830 1D060355 1D0E0416 041432EB FF43EE5E C1AA7FB4
  08AAF0D4 28F1B908 F538300D 06092A86 4886F70D 01010405 00038181 0010D7BE
  933DA5E0 1CA219C6 7B7B00A6 BBBF513A 1BF10C42 F94314C3 0DA8BAF5 415C4B33
  A3A2B36B F0E9C87E F8E92987 4FD45252 E337E5EF 21CBEBA4 9F8F9C13 3A8CF46C
  C1F7B900 6B688314 CB99B3C7 4CDCE17B 95395E13 2DC08808 4008950E 8A91E8DB
  E73886CB 291CDAF8 105127D2 8CA360E5 3CC0DE47 548F8496 63329433 43
        quit
voice-card 0
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  registrar server
voice register global
mode cme
source-address 10.37.50.20 port 5060
max-dn 25
max-pool 25
authenticate register
voice register dn  1
number 6205
voice register pool  1
id mac 0004.F2E8.22D5
number 1 dn 1
dtmf-relay sip-notify
username 6205 password 12345
codec g711ulaw
voice translation-rule 1
rule 1 /^9/ //
voice translation-rule 2
rule 1 /^.*/ /9&/ type subscriber subscriber
rule 2 /^.*/ /91&/ type national national plan any isdn
rule 3 /^.*/ /9011&/ type international international
voice translation-rule 3
rule 1 /^9/ // type unknown unknown plan unknown unknown
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 2
voice translation-profile OutgoingProfile
translate calling 2
translate called 1
voice translation-profile Outgoing_International
translate called 3
license udi pid CISCO2911/K9 sn FTX1412ALUM
username admin privilege 15 secret 5 $1$YJ75$JAqLXgu5wLe.O80EsAHnD.
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24
description att_pri_t1
controller T1 0/0/1
no ip ftp passive
interface GigabitEthernet0/0
description *** Uplink  ***
ip address 10.37.50.20 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
interface Integrated-Service-Engine1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.37.50.21 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 10.37.50.20
no keepalive
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication aaa
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.37.50.1
ip tacacs source-interface GigabitEthernet0/0
access-list 23 permit any log
tftp-server flash:SCCP42.8-4-2S.loads alias SCCP42.8-4-2S.loads
tftp-server flash:term42.default.loads alias term42.default.loads
tftp-server flash:term62.default.loads alias term62.default.loads
tftp-server flash:jar42sccp.8-4-1-23.sbn alias jar42sccp.8-4-1-23.sbn
tftp-server flash:apps42.8-4-1-23.sbn alias apps42.8-4-1-23.sbn
tftp-server flash:cnu42.8-4-1-23.sbn alias cnu42.8-4-1-23.sbn
tftp-server flash:cvm42sccp.8-4-1-23.sbn alias cvm42sccp.8-4-1-23.sbn
tftp-server flash:dsp42.8-4-1-23.sbn alias dsp42.8-4-1-23.sbn
tacacs-server host 10.35.1.100
tacacs-server host 10.230.65.44
tacacs-server timeout 2
tacacs-server directed-request
tacacs-server key 7 0538121D205B6E1B0A
control-plane
voice-port 0/0/0:23
sccp local GigabitEthernet0/0
sccp ccm 10.37.50.20 identifier 1 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
shutdown
dial-peer voice 6669 voip
description ** Exchange Unified Messaging **
destination-pattern 6669
session protocol sipv2
session target ipv4:10.37.0.63
session transport tcp
dtmf-relay rtp-nte
codec g711ulaw
fax rate disable
fax protocol pass-through g711ulaw
no vad
dial-peer voice 4200 voip
description LAX ext 42[0-5].
destination-pattern 42[0-5].
session target ipv4:10.37.0.25
dial-peer voice 6205 voip
description Polycom7000 Confroom1
destination-pattern 6205
session target ipv4:10.37.50.28
codec g711ulaw
dial-peer voice 5 pots
description outgoing_emergency
destination-pattern 911
port 0/0/0:23
forward-digits all
dial-peer voice 2 pots
description outgoing_subscriber
translation-profile outgoing OutgoingProfile
destination-pattern 9[2-9]..[2-9]......
port 0/0/0:23
forward-digits all
dial-peer voice 3 pots
description outoing_national
destination-pattern 91[2-9]..[2-9]......
port 0/0/0:23
forward-digits all
dial-peer voice 4 pots
description outgoing_international
translation-profile outgoing Outgoing_International
destination-pattern 9011T
port 0/0/0:23
forward-digits all
dial-peer voice 1 pots
description *** Inbound calls ***
translation-profile incoming CALLER_ID_TRANSLATION_PROFILE
incoming called-number .
direct-inward-dial
port 0/0/0:23
dial-peer voice 1000 voip
description BER ext [1-3]...
destination-pattern [1-3]...
dial-peer voice 4000 voip
description BER ext 4[0-1]..
destination-pattern 4[0-1]..
dial-peer voice 4300 voip
description BER ext 4[3-9]..
destination-pattern 4[3-9]..
description BER ext 5...
sip-ua
mwi-server ipv4:255.255.255.255 expires 3600 port 5065 transport tcp unsolicited
gatekeeper
shutdown
telephony-service
max-ephones 50
max-dn 100
cnf-file perphone
time-zone 13
dialplan-pattern 1 21XX9662.. extension-length 4 extension-pattern 62..
voicemail 6669
max-conferences 8 gain -6
dn-webedit
time-webedit
transfer-system full-consult
line con 0
privilege level 15
login authentication no_tacacs
line aux 0
line 67
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
session-timeout 120
access-class 23 in
exec-timeout 5 0
privilege level 15
password 7 104D000A0618
transport input telnet ssh
transport output telnet
line vty 5 15
session-timeout 120
access-class 23 in
exec-timeout 5 0
privilege level 15
scheduler allocate 20000 1000
end
