CUCM and DHCP interaction
andreac81_
I've two questions about interaction between CUCM and DHCP server.
1. In a network with a CUCM, IP-Phones and a DHCP server:
  • if the DHCP server goes down, does the IP-Phones work?
  • if the DHCP server is replaced with another DHCP server, are there changes in the CUCM or in IP-Phones configuration?
2. Is there any interaction between DHCP server and CUCM?
Jonathan Schulenberg
Yes until their lease expires. Then no.
No; however, there may be changes needed on the switches (ip helper) if the DHCP server is not in the local subnet.
Hopefully not. CUCM is capable of receiving it's IP addresses from DHCP but this is not recommended.
