CUCM and LDAP Integration for existing Cluster.
keanej
Level 3
Level 3
 I have a existing CUCM cluster running 10.5.2.15900-8
The end user database is stored on the publisher, currently circa 2000 entries.
What happens if I try to enable LDAP integration now...
SYSTEM | LDAP System | 'Enable Synchronizing from the LDAP Server'
Presuming, of course, that I have configured the rest of the parameters.
I am concerned that I will corrupt or reconfigure existing users.
I would like to configure LDAP and starting replacing users in controlled fashion - perhaps using the BAT.
I appreciate if I was starting fresh, this is straightforward, but I don't want to cause disruption to the existing cluster.
Is this possible ??
James
Manish Gogna
Hi James,
It will be non disruptive, please check the following post with similar query
https://supportforums.cisco.com/discussion/12435776/active-directory-integration-cucm-105
Manish
- Do rate helpful posts -
Manish Gogna
Hi James,
Manish
Thanks Manish
