CUCM and Two CUBA server
habouzyad
hi All,
I m actually using a CUCM connected to the CUBA 8.X with 4 client license.
I want add a second server to support 8 new client, so i have to use CUBA 9.X and to be installed to a new server ( CUBA 8. end of sale and support only max 6 client).
In wait to upgrade a license from CUBA 8.X to 9.X ,  i will in the first starting by using both server ( CUBA 8.X and CUBA 9.X).
I have the folowing questions :
1- it is possible to use two CUBA server   coneected to one CUCM ?
2- It is possible to configure a call to be received in queue in both CUBA Client ?
Thanks in advance
Cham
Jaime Valencia
I'm going to assume you refer to the CUBAC, right????
Because there is no product that just goes by CUBA
If so
1. Yes, configure completely separate integration
2. No
java
if this helps, please rate
Jaime Valencia
If so
2. No
java
Hi Jaime valencia,
Yes, I refer to the CUBAC .
Thanks a lot for the answer
