Hi, SPA942 is compatible with Call Manager express (CME) in cisco router2900 series?? Thanks in advace , Regards,
Hi all, I am trying to configure a CUBE (sip to sip) but it seems that it is not listening on port 5060 I have configured the voice service voip and sip-ua commands but when I try to set up transport tcp I get the following labo2921(config-sip-ua)...
Hi All this is a very broad question and i apologise in advance for my lack of IP telephony knowledge but i wondering if anyone is willing to help with QOS configuration? We have a new Avaya IP telephony system installed and want to configure the app...
Hi, I have a customer with only a ten channel ISDN30. In the morning they get hammered by customers so they experience being unable to make external calls out. They need however to be able to make calls out to clients. They have asked if there is a w...
Team, In hardware, we calculate the dsp resource avaialablity on MIPS/credits. How it is calculated in cucm Please consider!
HI All I have a query related to Call Routing . PFA the diagram for your reference. Lets assume I have some sites connected to Call Manager in a distributed scenario. There are two routes for connectivity between the sites and Call Manager : 1. IP...
Good afternoon! Using CUCM I have configered a 7965 phone to display internal extensions for speed dialling. Its abit of a cosmetic thing but the customer says that the extensions are appearing with the external symbol, the grouping of squares. Is th...
Hi, We have international calls with ! Pattern we can cut time-out with IP Phones by pressing # manually But the contact users in jabber will face this time out that the contact phone numbers not contain the # I need to know if we can add # automati...
Hello everyone, I'm having an issue with one way audio connecting to a sip provider. It looks like i'm not sending audio to them from the CUBE. here is my CUBE setup: version 15.4service timestamps debug datetime msec localtime show-timezoneservic...
Hi there all. I have a problem related to my CallManager Express (version 10.0) SIP trunk. On my site already configured SIP trunk between CME and CUE. I have configured DN for SIP phone, and SIP phones have registered on CME successfully, but ... A...
Hi All, i have a case where a client wants all calls except 34xx to have clid restricedand 34xx to be masked to 3400. its a 200 did range 34xx and 35xx dial-peer voice 1 pots destination-pattern 0T fax rate disable clid restrict direct-inward-dial ...
Hello Friends, I always tend to have a bit confusion with this calling and called number. Am I correct with the below, Calling number - From where the call was dialed or originated? Called Number - to where the call going to or terminated? Is there...
Hey Guys, I have a CUBE configured and working currently. Now the customer wanted to implement the Cisco Fax to Email app. So Ive installed 2xISDN E1 Wics into the same Router. Configure one E1 Port as Network side and the other User side. I have cre...
Hello, I have requested for our Telco to assist with setting up our PRI's to utilize the External Phone Number Mask so we can send this as our CPN. At first I recieved the answer that I wanted to hear in that they would set up the PRI's to send CPN i...
Hi ALL, Suddenly we cannot make outgoing but can receive incoming call.The attache is the config. Need your help. Thank you.
Subject | Author | Posted |
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM | ||
05-16-2025 12:03 AM |
User | Count |
6 | |
5 | |
2 | |
2 | |
1 |
