CUCM Call Control via SIP
I would like to is there a possibility to know and send SIP commands to CUCM:
a- how to Hang up a ongoing call ? any specific commands ?
b- how to know if a call was hung up by a user ? any specific commands ?
Your help is most appreciated.
Prasana
Regards, Prasana Kumar.P +919841027006
Jaime Valencia
AFAIK there is no way to hang up a call, not even via API
You can look at CDR to find out who finished the call.
java
if this helps, please rate
Thank you Jaime, for your inputs and if there are any additional inputs if you are aware of please do share and meanwhile i am posting this to Cisco Dev Net as well.
Jonathan Schulenberg
This question is more appropriate for the developer communities. Traditionally this has been done over CTI/TAPI/JTAPI, not SIP though.
https://developer.cisco.com/site/jtapi/index.gsp
https://developer.cisco.com/site/uc-manager-sip/index.gsp
Thank you Jonathan, for your inputs and if there are any additional inputs if you are aware of please do share and meanwhile i am posting this to Cisco Dev Net as well.
