CUCM. Call quality between regions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-04-2017 09:51 PM - edited 03-17-2019 11:18 AM
the problem is that if I assign the Default region to HQ phones and Region 1 to remote site phone, then
- man on the remote site hears well
- sound on the HQ site is bad (some words disappear, stutter and it's not clear what the other person is saying)
If I swap the regions (for the HQ phones - Default, for the remote - Region 1), then
- both sites hear each other well
What could be the reason?
- Labels:
Other IP Telephony
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-05-2017 04:01 AM
it's about your configurartion on region side...
when you go to server-> region -> you create 2 region .. you have to make sure about the max bandwithd when communicate with regi 1 to reg 1 ... and regi 1 to reg 2
you can force the cucm to use g729
I had this problem before ..
it will be ok ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-05-2017 08:37 AM
What codecs are defined between the regions?
How is your QoS configured between the sites? Do you have enough bandwidth in priority queue to support these calls?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-05-2017 11:25 AM
g729 use 8 kbit but alaw and ulaw (default) use 64 kbit
change your codec
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-05-2017 11:41 AM
Incorrect, both u and a-law variants use the same bandwidth.
Are you saying when you change it to G711 things work better or when using G729 things are better?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-06-2017 01:59 AM
g729 is better than g711in wan communication
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-06-2017 04:47 AM
I simply responded to your following statement:
"g729 use 8 kbit but alaw and ulaw (default) use 64 kbit"
