CUCM Cleanup
msmalik
Looking for recommendations as to how and what's the best possible approach to do a cleanup of CUCM.
CUCM Version: v14
DN's: 6000+
Devices: 5000+
There are a lot of DN's and Devices which are not used. What would be the best possible way to get rid of them ?
One way i can think of is to export Bulk reports and remove all that isn't used in like last 90 days.
Thankyou
5 Replies 5
To Remove DN not associated to a Device, you can   go on "Call Routing" ---> "Route Plan Report" and on "find" selector choose "Unassigned DN" to find all unused DN. You'll see that you can select "Delete All Found Items" option to delete all in one click.
For Unused phones, you mean unregistered ones?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
Yes i mean the phone which aren't registered in a couple of months period.
Thanks for you valuable suggestions.
you could login viacli on all cucm nodes and issue the following command :
show risdb query phone
It will show the last registration date since last reboot of cucm nodes.
Copy the result in a csv file and import on a spreadsheet.
Than filter all lines with the unr status.
Keep in mind that the timestamp is showed in epoch format that you can easily convert with a excel formula.
Carlo
bspalmer1
One thing that would be a good idea before you bulk delete anything would be to take a bat file backup of everything so if you accidentally hit something still in use you can either import it from that bat file or manually rebuild it exactly as before.
good idea
