Cucm coparate directory
zumriatha
I'm new for cucm.
Just got my be6k running and configure internal calls with users and phones.
I can dial manually other phones but not through the coparate directory.
The names are populated in the coparate directory but grayed out also it shows offline below the name I cannot dial through the coparate directory any ways to fix this.
Tnx
George Sotiropoulos
Could you clarify from what type of endpoint you try to dial-out, is it a Cisco IP Phone or Cisco Jabber for Windows?
Hope the above helps,
gsotirop
