03-12-2017 01:47 PM - edited 03-17-2019 09:47 AM
I'm unable to get the Corporate directory working on a Cisco 8851 phone. LDAP (system, directory, and authentication) are configured and am able to import LDAP users into CUCM.
The following entries are configured on the phone's Web GUI. DNS resolution resolves to macaw.dlw.com.
Receive the following error:
Receive the following error on the 8851
Host not found.
| Information URL | http://macaw.dlw.com:8443/ccmcip/GetTelecasterHelpText.jsp | |
| Directories URL | http://macaw.dlw.com:8443/ccmcip/xmldirectory.jsp | |
| Messages URL | ||
| Services URL | https://macaw.dlw.com:8443/ccmcip/getservicesmenu.jsp | |
| Idle URL | 0 | |
| Idle URL time | 0 | |
| Proxy server URL | ||
| Authentication URL | https://macaw.dlw.com:8443/ccmcip/authenticate.jsp |
Can someone point to me where the Java code is modified for the URLs
03-12-2017 02:51 PM
Hi Dennis,
Go under CCMadmin page >> System >> Enterprise parameters. and modify the values from hostname to IP and then check if you still have the issue.
Ensure you reset the phone after making the change, so that values get modifies in the config file.
Hitesh
03-18-2017 06:21 PM
Thank you for the suggestion of replacing DNS with IP Address. It wasn't
One thing to note in my
When Telneting from a local LAN using IPv4 I receive a connection but when attempting using the IPv6 address it goes nowhere.
This leads me to believe that Tomcat isn't IPv6 aware.
03-13-2017 02:45 AM
As mentioned, I don't think DNS is resolving. Just do the suggestion and see if the problem is fixed.
