CUCM CRITICAL ERROR TO A FRESH INSTALLATION
We have two MCS7825H3-K9-CMB2 (149 GB HDD, 8GB RAM)
We have these servers in the lab so we have installed 8.0.3 for testing proposes
Now we want to perform a fresh installation to these servers and finally to restore a data from an active cucm cluster
I tried to perform a fresh installation  , unfortunatelly without success
Error:Critial error
Disk size (149 GB) failed , check (Min Needed 232 GB)
Notes:
i thought that the partitions from the existing version , occure this issue , so i deleted all the partitions
But with out any success
versions that i tried to install are: 8.0.2,  7.0,  7.1 (149 GB are enought for also version 8.6)
cc
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Gordon Ross
Level 9
Level 9
Try deleting the RAID configuration in the BIOS.
GTG
Please rate all helpful posts.
I have deleted the RAID CONFIG and rebulit it again
Unfurtunatelly the same results
i have upload the dump file
can anyones help/??
This discussion has been modified to comply to the CSC terms of use conditions.
