05-08-2012 03:54 AM - edited 03-16-2019 11:02 AM
We have two MCS7825H3-K9-CMB2 (149 GB HDD, 8GB RAM)
We have these servers in the lab so we have installed 8.0.3 for testing proposes
Now we want to perform a fresh installation to these servers and finally to restore a data from an active cucm cluster
I tried to perform a fresh installation , unfortunatelly without success
Error:Critial error
Disk size (149 GB) failed , check (Min Needed 232 GB)
Notes:
i thought that the partitions from the existing version , occure this issue , so i deleted all the partitions
But with out any success
versions that i tried to install are: 8.0.2, 7.0, 7.1 (149 GB are enought for also version 8.6)
cc
05-08-2012 06:00 AM
Try deleting the RAID configuration in the BIOS.
GTG
05-09-2012 02:00 AM
I have deleted the RAID CONFIG and rebulit it again
Unfurtunatelly the same results
i have upload the dump file
can anyones help/??
07-13-2015 02:04 PM
This discussion has been modified to comply to the CSC terms of use conditions. |
