ā11-21-2012 06:22 AM - edited ā03-16-2019 02:19 PM
Hi Folks
We will move one customer to UCS servers
Questions:
1) CUCM and CUC must be at least 8.x version in vm
2) what about ccx and cup.Can we proceed in ucs with version 7.1.x for cups and ccx?
cc
Solved! Go to Solution.
ā11-21-2012 06:58 AM
The following document should address your query:
HTH.
Harmit.
ā11-21-2012 06:59 AM
1 Yes, 8.02) or later
2 No, you need to run versions supported for virtualization
I'd strongly suggest you to review the virtualization wiki
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ā11-21-2012 09:57 AM
Hopefully the following links address your queries:
http://docwiki.cisco.com/wiki/OVA_Template_Details_for_Unified_CM_Release_9.0
HTH.
Harmit.
HTH.
Harmit.
java
ā11-21-2012 08:49 AM
Thank you both fro your answers
One last think
can i use ova file for version 9 and install first cucm version 8.5 and then move to 9?
Where i can review these infos?
HTH.
Harmit.
ā11-21-2012 10:07 AM
Cheers
cc
