CUCM DB Replication Problem
Ekin Gumus
Hello All,
Sometimes db replication of CUCM cluster is (on publisher) state turns to 3 so after restart of publisher it goes back to "2" but I need to find out why it changes as "3" sometimes. Any idea how to get logs or figure out why this happens?
Thanks.
Manish Gogna
Hi Ekin,
You can check the following doc for information about Datbase replication architecture and troubleshooting
https://supportforums.cisco.com/document/52421/troubleshooting-cucm-database-replication-linux-appliance-model
Manish
Suresh Hudda
Hello Ekin,
Which version of CUCM you have ? Make sure NTP is synced all the time.
Suresh
Deepak Rawat
Event Viewer (Application & System) logs along with NTP logs should give an idea why this is happening. However, most importantly make sure that you are using an IOS based NTP source there and not a Windows based to start with.
Deepak
