CUCM Device Registration Search
Jason Amick
Was curious to know if it is possible to search using CCMadmin to search and see what devices are registered to which subscribers?  I have not found an easy search/filter in call managers UI to find what I am looking for.  All devices should be registered to the primary sub unless there is an outage then all devices should fail over to the secondary sub.  I have looked in RTMT using "device search" and think I can get the information needed that way but thought there has to be a way I can achieve this from the web interface of CUCM.  Thanks for any help!!
Setup Consists of:
CUCM version: System version: 8.6.2.23900-10
- 1 Publisher
- 3 Subscribers
Ayodeji Okanlawon
You can use the following command
  • show risdb query phoneextn phone
This needs to be run on each cucm server. It will display the phones registered to that server and there ip addresses. You can export the result to excel and sort values out.
Please rate all useful posts
17 Replies 17
Ayodeji Okanlawon
Ayodeji:
Thanks for the information, is that command no CPU intensive and could be run during business hours?  Thanks again!!
No it is not. It is very quick too and yes you can run during business hours..
Ayodeji:
Using this command on our secondary subscriber shows a count of 799 devices but after searching for several devices included in this query I find them registered to the primary sub.
The query list all the columns in risdb phone table. I
I am shocked to hear that the devices are registered else where as this will only show devices registered to the server. This is a real time information and as such cant be devices registered else where. I just tested this on my cluster now and it works as expected.
----------- Phone Information -----------
#TotalPhones, #TotalRegistered, #RegisteredSCCP, #RegisteredSIP, #UnRegistered, #Rejected, #PartiallyRegistered, StateId, #ExpUnreg
1137, 1123, 1120, 3, 12, 2, 0, 46024,0
I agree its odd.  We have 3 subscriber .12, .13, and .14.  When I run this query on the secondary .13 one of the (799) results I received would be:
SEP001BD52C9DB8, Sherri Snovell, 10.1.42.111, , 3, 0, 001BD52C9DB8, unr, SCCP, 30018, yes, 1, 30044, NoUserId, 27292, 1420687739, 1, SCCP41.9-3-1SR1-1S, SCCP41.9-3-1SR1-1S, , , , 0, , 1420687739
When I look that mac address up in CUCM it shows the phone clearly registered to .12 the primary.
its because you are not interpreting the output correctly..This phone is cleary unregistered with this server
The unr by the phone means unregistered.
This is an example of a registered phone
SEP00137FDD3433, NG-EM, 10.1.8.10, , 0, 0, 00137FDD3433, reg
You can see reg by the mac address of the phone.
It is possible that this phone has registered with this server sometimes in the past but it not registered as at the time you ran the command.
Hi Jason.
With field "RegStatusChg TimeStamp" you can also see when the device has changed its status (from reg to unreel and/or viceversa)
Carlo
Please rate all helpful posts "The more you help the more you learn"
Very useful information you guys have provided which I could not get out of a TAC case.  Thanks again.
Hi Jason.
Very glad to hear that our answers were useful.
Please remember to rate useful posts and mark as correct the answer that solved your issue
Carlo
Useful stuff guys (+5); I didn't know about that command though I knew about the base API :-)
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Jason.
+5 to my buddy Deji for his excellent suggestion ;)
RisDB shows you phones in both registered and unregistered status.
If you see some phones in both primary and secondary subscriber, that means that those phone are in Unregistered status in one server and Registered status in the other server
If you see in the output you can note that there is a RegStatus field which will be reg for registered phones  or unr for unregistered.
I suggest you to export the output of that command and put it in a text file and use it with Excel importing it as a CSV.
Carlo
Carlo:
Thanks for your input and you are right the 799 devices showing up when running this command all listings show them as unregistered.  Thank you both for your help I think I have enough information here to get the information I am looking for.
Carlo (great explanation +5)..
