CUCM Dial Issues
Lasha Lomjaria
We have CUCM 8.6.1 and we have strange problem. On some phones and some Directory Numbers, when we push New Call Button on phone and Dial Directory Number, phone doesn't ring about 7-10 seconds and then rings. But if we dial another directory number, it works without problems.
Do you know what may be the problem?
j.huizinga
Level 6
Level 6
7-10 seconds seems a timeout, you must have some overlapping patterns, with some extensions.
For example you might have extensions 2300, 2100 and a route pattern 21XXXXXXXX
2300 will dial correct, but 2100 will also match the route pattern, so waits for time out.
JH
j.huizinga
Level 6
Level 6
JH
We don't have any overlapping patterns. For example one extension is 446. some phones dial without problems, but others not.
Then you have to enable logging, and check what is the difference between one call and the other.
Still 7-10 seconds seems a time out, do the phone have the same CSS?
Or just give (temporary) some phone the same CSS and see if there is difference.
JH
Here is call log. I dialed from 730 to 446, which had problem. Then I dialed 446 to 733 and it worked normally:
2013/09/04 17:48:19.404|CC|SETUP|37536864|37536865|730|446|446
2013/09/04 17:48:19.406|CC|OFFERED|37536864|37536865|730|446|446|SEPAC162D02E19C|SEP2C542D064AC2
2013/09/04 17:48:20.739|CC|RELEASE|37536864|37536865|16
2013/09/04 17:48:30.916|CC|SETUP|37536866|37536867|446|733|733
2013/09/04 17:48:30.918|CC|OFFERED|37536866|37536867|446|733|733|SEP2C542D064AC2|SEP1C17D337C2E3
2013/09/04 17:48:32.185|CC|RELEASE|37536866|37536867|16
I'm new in CUCM world so I don't now much
They have same CSS...
I solved the problem. Reason was overlapping pattens. I had Call Park pattern 44XX.
Thanks for help.
