cucm does not terminate calls
atle.larsson
Hi all
We have a problem with calls not being terminated when the phone is not registered or is not a defined number in our cucm.
What happends is that it strips the last two digits and puts +47 (national prefix) in front of the number instead. So when someone calls a "unregistered" number 12345678 somewhere it transforms that into +47123456.
we have cube in front of the cucm, and that transforms numbers that begins with +47 into 0 for the cucm. That is there if someone has a unanswered call they can just call back with 0 in front for outgoing pstn.
example:
calling number 12345678
Cube transforms: 012345678
trunk removes predot 0
number is in our range but does not exist
call bounces back from cucm and goes out with: +47123456
We want these calls to be terminated, any suggestions?
Atle L
Dennis Mink
in your example:
example:
calling number 12345678    (is this an inbound call?)
Cube transforms: 012345678  (why add a 0 and then strip it on your trunk?)
call bounces back from cucm and goes out with: +47123456  (where do you remove the 78 and prefix +47)
Can you add your cube's config and add a debug ccsip to this post.
thanks
Please remember to rate useful posts, by clicking on the stars below.
