CUCM - Dropped calls via MGCP
Pascal Douce
Hi Guys,
I'm currently facing an issue where calls to a 7962G are getting dropped. This is an intermittent situation and there is no flow or time which will indicate when the call will drop.
I've gathered the CDRs corresponding to the time when a call was last dropped and noticed the following :
Calling party : 43207XX
Called Party : 40691XX
DATE TIME ORIGINATION : 08:22
DATE TIME CONNECT : 08:22
DATE TIME DISCONNECT : 08:23
Duration : 72 seconds
Call flow : PSTN -> MGCP Gateway -> CUCM -> Phone
Orig Cause Location : 2 (No route to specified transit network(national use)
Orig Cause Value : 16 (Normal Call clearing)
Destination Cause Location : 0 (No error)
Destination Cause Value : 0 (No error)
DATE TIME ORIGINATION : 08:23:51
DATE TIME CONNECT : 08:23:54
DATE TIME DISCONNECT : 08:23:54
Duration : 0 second
Call flow : PSTN ->MGCP Gateway -> CUCM -> Phone
Orig Cause Location : 0 (No error)
Orig Cause Value : 47 (Resource unavailable)
Destination Cause Value : 47 (Resource unavailable)
I was wondering what could cause the Orig Cause Location 2 and 47.
Any help would be much appreciated. Thanks!
Pascal
7 Replies 7
Amine Nouasri
Level 3
Level 3
Code 47 means CM is unable to allocate a resource. It could a DSP, codec issue, media resources allocation. If you can post some debugs regarding a failed call. We can maybe point you out in the right direction.
debug voip ccapi inout
debug mgcp packet
Please rate helpful answers!
Hi Amine.
Thanks for your reply.
Since we can't reproduce the issue whenever we want, is it safe to launch the above debug commands continously on the Router ?
If this is OK, we will setup it up until the issue is reported again. We can setup a syslog server to gather the logs.
Pascal
Pascal,
Yes, you can setup a syslogg server and enable the debugs, you can leave the logging for a long time without affecting the gateway performance.
In addition, you'll need to enable CCM traces:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Pascal Douce
Hi Amine and Jorge,
Let me setup the syslog server and CCM traces and I will update this post with the debug outputs when issue is reported again.
BR
Pascal
Pascal Douce
Hi All,
The issue was reported again this morning.
Here's what i've observed on CDR:
Time of call : 10:03:15
Calling Party : 46427XX
Originated Cause Value : 16
Originated Cause Location : 2
It seems that the issue is coming from PSTN with cause code 2. This code means "no route to specified transit network(national use)"
I managed to get the output for debugs mentioned.
Grateful if any can help out.
Pascal
Hi Pascal,
Log shows that gateway has received MDCX from CUCM stating M = recvonly.
For further analysis, detailed RTMT trace is required along with debug isdn q931.
Please see if it's possible to manage.
Also, call drops only in case of incoming or outgoing also? It happens with particular dn or every dn of 7962 phones?
Nishant Savalia
Regards, Nishant Savalia
Hi Nishant,
I have enabled debug isdn q931 on the gateway. I will work on the CCM traces and make them available when issue occurs again.
Ques :Also, call drops only in case of incoming or outgoing also?
Ans : Well it seems that this issue is occuring for incoming calls
Ques : It happens with particular dn or every dn of 7962 phones?
Ans : For now only one 7962 G has been deployed for admin and a few 6921 phones for guests. No complains have been received from guest side.
I've managed to get the following traces for the above call
2013/09/23   10:03:15.666|CC|SETUP|48633197|48633198|46427XX|40691XX|40691XX
2013/09/23   10:03:15.668|CC|OFFERED|48633197|48633198|46427XX|40691XX|40691XX|S0/SU0/DS1-0@LBM-MCC2-GW2901-01.lbm.local|SEP203A07FD8359
2013/09/23   10:05:22.518|CC|RELEASE|48633197|48633198|16
I have one more question. On the Trace Filter Settings, should i tick all options or are the one selected(See attached) ok?
Thanks and Regards,
Pascal
