CUCM failed to upgrade from 7.0.2 to 7.1.3
markjiang
We plan to up upgrade cucm from 7.0.2 to 7.1.3.But failed everytime.
We have try CUCM 7.1.3.20000-2 and 7.1.3.10000.And try tfp stftp or DVD to upload the upgrade file.
I are sure that the upgrade file is ok.
But everytime when it started to upgrade, it prompted a error in 30 minutes.
We also try to upgrade to 7.1.2.And everything is ok.
Can anybody help me?
I had this issue as well and not sure why so instead I downloaded the 7.1.3 file from cisco's website then burned the ISO to DVD then the upgrade worked fine. Might try that route.
Tracy
Justin Brenton
Level 4
Level 4
What is the error that was given?
Justin
Sascha Monteiro
Level 6
Level 6
Are you running the Beta release of 7.0?
We are in our lab, and cannot upgrade it either..
Going to try and run exports and import into a clean install of 7.1....
Hi s.monteiro,
We bought a new CUCM platform.Cisco shipped us the DVD.
And we tried to upgrade CUCM from 7.1.1 to 7.1.3.It was the same.
Have your succeed in upgrading to 7.1.3?
Tracy
