CUCM -> Flowroute outbound calls working but dial tones are not regonized
Signups
Hi, I've noticed a strange issue with my CUCM deployment.
Its a fairly simple setup with a cisco 2901 as the CUBE connected to flowroute with their default setting and the Max Audio Bit Rate is set as
64 kbps (G.722, G.711)
However when I dial multiple known working numbers that use dial tone recognition (banks, phone meetings etc) the dial tones are ignored by these systems.
Ive tried on multiple devices with the same result (IPCommunicator, IP Phones and even xlite).
Can anyone suggest what may be causing this to happen ?
R0g22
Add the following -
conf t
voice class uri IN sip
host ipv4:X.X.X.X >> IP of CUCM. 1 node
host ipv4:Y.Y.Y.Y >> IP of CUCM. 2 node
dial-peer voice 100 voip
description CUCM INBOUND
session protocol sipv2
incoming uri via IN
voice-class sip bind control source-interface <LAN interface>
voice-class sip bind media source-interface <LAN interface>
dtmf-relay sip-kpml rtp-nte
codec g711ulaw
no vad
Add the voice-class binds on your flowroute facing DP's. The interface would be your external/ITSP facing interface.
9 Replies 9
Georgios Fotiadis
This is a DTMF negotiation issue. What is the dtmf-relay configured under your dial-peers (incoming from eg. CUCM and outgoing to Flowroute)?
Georgios
Please rate if you find this helpful.
R0g22
For starters, add "dtmf-relay sip-kpml rtp-nte" to your incoming and outgoing dial-peers and then test.
Yes I had dtmf-relay rtp-nte ive run
no dtmf-relay
followed by dtmf-relay sip-kpml rtp-nte
Saved and reloaded the cube but the issue remains on every dial tone regonition system i call.
Here are my two dial peers
dial-peer voice 101 voip
 description *** Outgoing Flowroute ***
 translation-profile outgoing addlocal
 destination-pattern 1[2-9]..[2-9]......
 session target dns:sip.flowroute.com
 voice-class codec 1
 voice-class sip asserted-id pai
 voice-class sip profiles 1
 media-class 3
 dtmf-relay rtp-nte
 no vad
dial-peer voice 102 voip
 description *** Outgoing International ***
 destination-pattern 011T
 voice-class codec 1
 no voice-class sip asserted-id
 media-class 3
 dtmf-relay rtp-nte
 no vad
R0g22
Enable the following debugs -
debug ccsip message
debug ccsip error
debug voice ccapi inout
debug voip rtp session named-event
Reproduce the issue and copy the logs in a text file.
Ok here are the results. Again no matter how many numbers I pressed I could not get it to read a single one. The remote system acts as if nothing but silence was played back
R0g22
IOS is selected DP=0 due to which dtmf negotiation is failing -
Mar 9 19:59:52.072: //-1/6CC2F1800000/CCAPI/cc_api_call_setup_ind_common:
Interface=0x41C17004, Call Info(
Calling Number=4206969696,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=17127704160(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=41
Attach a "show run" from the CUBE please.
Sure it is also hosting 4 flexnet access points on the POE module hence the trucking and there is also a FXO card setup
R0g22
Add the following -
conf t
incoming uri via IN
codec g711ulaw
no vad
Perfect thanks a million that fixed it. I hope this helps someone else too.
