Showing results forĀ
Search instead forĀ
Did you mean:Ā
CUCM H323 gateway FXO line monitoring
Marc El Achkar
I have a CUCM and an h323 gateway, is it possible to monitor the fxo lines for incoming and outgoing calls from the phone to know if busy.
Best regrads
Mark
Manish Gogna
Hi Mark,
You can do it through RTMT. Please check the following links for details
https://supportforums.cisco.com/discussion/11057436/fxo-card-monitoring
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/9_0/rtmt/CUCM_BK_CA3A517A_00_cisco-unified-rtmt-administration-90/CUCM_BK_CA3A517A_00_cisco-unified-real-time-monitoring-tool_chapter_010.html
Manish
- Do rate helpful posts -
Thank you for your answer, but what i need is to monitor it from the phones and not from RTMT
Hi Mark,
Unfortunately there is no native feature in Cisco IP phones to monitor a FXO line. You may need to develop a customized solution / script to achieve this.
Manish
