CUCM: Hotline + Type Digits
FPENTEADO
Hi Everybody
I create a Hot Line (TP+ CSS) that works fine and follow until Route Pattern. But I'd like to Prefix 2 digits and Type Other 3 digits after Digits match Translation Pattern
My  Configuration is
Translation Pattern _______ (empty)
Called Party 19123
Route Pattern 19XXX
Is there a possibibility that when the Calling goes Off Hook, the hotline prefix 19 and the user type other 3 numbers?
3 Accepted Solutions
zdesignstudio
Level 4
Level 4
There is no way to nativily do this from within CUCM.
Remember to rate useful answers and mark your question as "answered" if applicable
Please rate useful posts and mark answers as correct if applicable.
You can do manipulation where ever you want but the simple rule is, you can't expect user to dial any number or give input once call has been made.
- Vivek
Correct. You cant automatically send digits after the call has been setup.
zdesignstudio
Level 4
Level 4
It's impossible even if I modify route pattern (stripping 19) or make Lookup or Sip Dial Rule (my phone is SIP)?
- Vivek
