03-09-2015 10:36 PM - edited 03-17-2019 02:16 AM
I have created services and service profile on CUCM 10.5 and assigned to local user (NO LDAP SYNC) in user management>end user, but these users are not sync with CUP i see 0 users in CUP 10.5
Any hint for troubleshooting.
thanks
03-10-2015 03:11 AM
Please check if "Enable User for Unified CM IM and Presence (Configure IM and Presence in the associated" parameter is checked on end user page.
03-10-2015 05:09 AM
yes vivek it is checked.
03-10-2015 05:54 AM
If all required configuration in call manager is correct, try to run "system troubleshooter" in CUPS if it shows you any integration error.
Vivek
03-10-2015 11:28 PM
Dears thanks for the reply,
actually my colleague removed the tick from Enable User for Unified CM IM and Presence now
the user are appearing in the CUP,
i want to know when we add a subscriber in the default sub cluster before adding the subscriber in the default subcluster the services should be stop on the subscriber ?????
thanks
03-12-2015 03:48 AM
Not needed.
Only when you enable "Enable High Availability" on CUCM for IMP you might restart the IMP servers (at least that is what I do)
03-10-2015 07:21 AM
IMP (CUP) version 10 are now subscribers to the CUCM publisher.
When you enable the user for "Unified CM IM and Presence" the user should be visible in IMP (System/Presence Topology)
Did you enable all services on IMP?
