06-26-2014 07:18 AM - edited 03-16-2019 11:13 PM
I have to perform a Refresh Upgrade to 10.5 for a client who has the following UC apps on a virtual environment:
CUCM version 9.1.1
IM and Presence version 9.1.1
CUC (Unity Connection) version 9.1.1
A. I see on the CUC Upgrade document below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/upgrade/guide/10xcucrugx.pdf
P.39 --> Change Guest Operating System after CUC Upgrade to Red Hat Enterprise Linux 6 (64-bit). But nothing about the Network Adapter.
B. I see on the CUCM 10.0 Upgrade Guide:
Page. 44:
Step 3: Change the configuration of the VM as needed (Guest OS, ...) Step 4: Modify the Network Adapter to use VMXNET 3 Adapter type as steps before the CUCM upgrade.
My questions would be:
1. Do I need to change the Network Adapter for CUC as well? If yes, should this be done before upgrade or after?
2. What would be the implication of not changing the Network Adapter from "Flexible" to VMXNET3?
06-03-2016 10:45 AM
If you mean that by installing the COPs required for such upgrade, it will automagically change the OS version in the VM specs (or anything else like RAM or vDISK size), NO, it will NOT, the upgrade guide explains this is a manual change, the pre-upgrade tasks chapter explains this.
The code for RHEL will be upgraded by the upgrade procedure, but changes to the VM specs, have to be performed manually, if you haven't you need to review the upgrade guide and RNs.
06-03-2016 10:52 AM
Thank you for explanation.
08-26-2016 02:36 AM
Hi jaime,
is it mandatory to change the the NIC to VMXNET3 before the upgarde,i thought of
changing the NIC after the upgarde ?
regards
balaji b
08-26-2016 07:45 AM
The upgrade documentation has the steps to change the VM specs in the pre-upgrade tasks.
That's the officially supported method, you can go ahead and try, it *should* work
02-28-2017 10:12 PM
Upgrading Cisco Unity Connection Guide:
8 Follow the upgrade process on the Unity Connection cluster:
• (RU upgrades only)
• ( L2 upgrades only)
9 Confirm that publisher server has Primary status and subscriber server has Secondary status.
10 (Unity Connection 9.1(2) or earlier versions only): If you are upgrading from Unity Connection 9.1(2) or earlier versions to Unity Connection 11.x, update the following virtual machine settings on both publisher and subscriber server through VMware vSphere client: a Change the Guest Operating System version to match the requirements of the Unity Connection 11.x. b Modify the network adapter to use the VMXNET 3 Adapter type.
CUCM doc indicates adapter should be changed before the upgrading. Please ask cisco TAC to clarify.
