CUCM inbound calls failover
vantonenko
I have a question about receiving incoming calls, when Publisher is down.
My provider gives me IP telephony with two SIP-trunks for outgoing call, and one SIP-trunk for incoming call (Routed to Publisher), therefore, when Publisher is down, we can't receive incoming calls.
How can I provide inbound calls, when publisher is down (or on maintenance)?
What devices is used for this purpose? We also have voice-enabled router, with CME, can I use it?
Thank you.
you can use CUBE (SIP to SIP). with dial-peers & preference, you can direct the calls to different server in CUCM group
//Suresh Please rate all the useful posts.
5 Replies 5
Thank you Suresh,
As i understand, i can use CME instead CUBE, cause it has SIP to SIP and dial-peer with preference functionality? If i right, why CUBE better than CME in that case?
U can use 2 dial-peers with monitor probe icmp-ping
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/dialpeer/configuration/15-mt/vd-15-mt-book/vd-pstn-fallback.html
No need for using CUBE
Thank you, Emil
Before I try this, i want to clarify that CME can route calls from SIP-trunk to SIP-trunk without "border element mode".
I never met this configuration, so i afraid about this.
Can you dispell my doubts?
Yes U can use it without CUBE
All that U need is uck9
U can check it so
Activate demo for uck9
Voice service voip
allow-connections sip to sip
then configure dial-peers and make call
