01-26-2015 07:50 AM - edited 03-17-2019 01:43 AM
Hello everybody,
Please check how I can fix the situation, thank you in advance.
On a router I added the commands:
ccm-manager config server 1.1.1.1
ccm-manager config
The router pull from TFTP(CUCMv.8.) the config BUT only after reboot of the router.
Some of my colleagues are telling me it's a normal case. But I haven't seen it in the official documentation, have I missed something?
You can see the situation in details here:
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE_IVS-M), Version 15.1(2)T1, RELEASE SOFTWARE (fc1)
<<< 1 STEP >>
ROUTER#sh debugging
MGCP:
Media Gateway Control Protocol media events debugging is on, trace level Verbose
Media Gateway Control Protocol nas pkg events debugging is on, trace level Verbose
Media Gateway Control Protocol events debugging is on, trace level Verbose
Media Gateway Control Protocol errors debugging is on
Media Gateway Control Protocol packets debugging is on
Media Gateway Control Protocol parser debugging is on, trace level Verbose
Media Gateway Control Protocol VoIPCAC debugging is on, trace level Verbose
Media Gateway Control Protocol System Resource Check CAC debugging is on, trace level Verbose
Media Gateway Control Protocol endpoint database debugging is on, trace level Verbose
Media Gateway Control Protocol state transition debugging is on, trace level Verbose
Media Gateway Control Protocol inout debugging is on, trace level Verbose
Media Gateway Control Protocol gcfm debugging is on, trace level Verbose
BR1-POD1-RACK2#ping 10.1.1.1
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
ROUTER(config)#ccm-ltmanager config server 10.1.1.1
ROUTER(config)#ccm-manager config
ROUTER(config)#^Z
ROUTER#
Nov 28 16:34:05.372: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_by_ifn(1330):[lvl=0]Entered
Nov 28 16:34:05.372: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_tree_link_by_ifn(1149):[lvl=0]Entered
Nov 28 16:34:05.372: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_tree_link_by_ifn(1156):[lvl=2]endptdb for protocol 0 does not exist.
Result: no debug messages at all, I restarted from CUCM side as well.
<<< 2 STEP >>>
wr, reload
RESULT:
It downloaded the config from the TFTP-server(CUCM).
ROUTER#sh ccm-manager config-download
Configuration Auto-Download Information
Current version-id: 1416469737-5bc4619e-8ca7-452e-b4f4-1f870bcc38b1
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 1
Download Failed : 0
TFTP Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
Configuration Error History:
ROUTER#
<< BUT: >>
ROUTER#sh ccm-manager hosts
MGCP Domain Name: ROUTER.TEST.ru
Priority Status Host
Primary Registering with CM 10.1.1.1
First Backup None
Second Backup None
< From CUCM side it is also looking as unregisting gateway. >
< Reset from CUCM side, no result.>
ROUTER(config)#no mgcp
WARNING: no mgcp: Teardown MGCP application may take a while to clean up resources
ROUTER(config)#mgcp
ROUTER(config)#
Nov 28 16:48:59.808: //-1/xxxxxxxxxxxx/MGCP/mgcp_init_dyn_payload_types(3277):[lvl=1]used payload type map = 2F400003
Nov 28 16:48:59.808: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_state_change(4876):[lvl=0]
MGCP Application state change:old_admin_state=0, new_admin_state=2, current oper state=0, old_graceful_shutdown=0, new_graceful_shutdown=0
Nov 28 16:48:59.808: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_state_change(4888):[lvl=1]MGCP APP Startup
Nov 28 16:48:59.812: //-1/xxxxxxxxxxxx/MGCP/mgcp_app_startup(4772):[lvl=0]sched time not enabled
Nov 28 16:48:59.812: //-1/xxxxxxxxxxxx/MGCP/mgcp_app_init(3864):[lvl=0]MGCP Application Subsystem INIT
ROUTER(config)#
<<< 2 STEP >>>
wr, reload
Result:
Primary Registred with CM 10.1.1.1
First Backup None
Second Backup None
So in my case, I need to reboot the router twice to get registered MGCP gateway on CUCM.
What do you think about the situation? What I need to check? Thank you or anyone for any comments.
Best regards,
Dmitry
01-26-2015 12:54 PM
You don`t need to reboot the router but you DO need to reset the mgcp protocol.
ROUTER(config))# no mgcp
ROUTER(config))# mgcp
MK
01-27-2015 01:49 AM
Hi, thank you for your reply. But it is not the case, I did it as well.
Dmitry
01-28-2015 08:29 AM
Try to reset the MGCP protocol twice. For some reason the first reset doesn`t take place.
01-29-2015 05:40 AM
hi,
sorry no results. I think it is rather a bug. anyway, thank you for your message.
Dmitry
01-29-2015 12:42 AM
Dmitry looks like it is software bug
I configured more than 100 router using MGCP (28xx,38xx,29xx,39xx etc) I had some problems with registration but all of them was because of wrong configurations
01-29-2015 05:39 AM
I can't approve it right now. I will check it later. Thank you for your clue.
Dmitry
