CUCM License File Upload Error.
boonchin.ng
Hi all,
Am getting the following error (attached image) while trying to upload a device license to Cisco UCM 7.1.5, verified that MAC Address is correct.
Also, trying to understand the relation between INCREMENT PHONE_UNIT cisco 8.0 permanent uncounted \ and the actual UCM version? When the license file indicate cisco 8.0, does this means the file can only be used on UCM 8?
Appreciate your kind advice.
Thanks!
Jonathan Schulenberg
I think this is failing because it's set for a virtualized installation (i.e. license MAC). Email the license to licensing@cisco.com and tell them that this is not a VMware installation. If memory serves it will change "HOSTID=HOSTNAME=" to just "HOSTID=".
Please remember to rate helpful responses and identify helpful or correct answers.
