10-09-2015 12:21 AM - edited 03-17-2019 04:32 AM
Hi Experts,
What this total memory and used memory signify in this output. Is this shows that around 97 percentage of usage from the current memory allocated to the VM ?
admin:show process load
top - 23:59:52 up 1 day, 46 min, 1 user, load average: 0.49, 0.30, 0.34
Tasks: 245 total, 1 running, 244 sleeping, 0 stopped, 0 zombie
Cpu(s): 7.0%us, 3.5%sy, 0.0%ni, 87.3%id, 2.0%wa, 0.0%hi,
0.1%si, 0.0%st
Mem: 3925704k total, 3809228k used, 116476k free, 9700k buffers
Manish
Solved! Go to Solution.
10-09-2015 01:13 AM
Hi Manish,
You see these high values because of the way Linux works. When the Linux system is not under memory pressure, all of the kernels caches will slowly grow over time. Linux prefers to keep larger caches just in case someone needs information in the cache. After all, there is no reason to return cachememory if no one really needs it. This cache memory is readily available when any process needs more memory.
http://www.cisco.com/image/gif/paws/109478/Memory_Issues_CUCM.pdf
Manish
- Do rate helpful posts -
10-09-2015 01:13 AM
Hi Manish,
Manish
02-19-2019 01:30 AM
Manish,
The link you posted doesn't work. Can you post an updated link please?
I've got a customer asking me about the same thing on their cluster and rather than just going back to them and saying "it's nothing to worry about" it would be good if I could send them a link to a Cisco doc but I haven't been able to find one.
Vincent
01-02-2019 01:22 PM
Manish.
This link no longer works.
Do you have a substitute link?
Thanks.
--Jerzy
