CUCM - Off-hook Default to 2nd DN
michahal
Does anyone know of a way in CUCM to have a 2nd or 3rd line apperance on a phone be the default for when a user goes off-hook?  I have a main line and a personal line on a phone.  Main line is the first one listed and the personal is the second.  When the user goes off-hook and hit's their VM button, it dials into Unity Connection and tries to access the wrong extension.  I realize I change the Prime Number option but then a user would have to select a line.
Mike
Rob Huffman
Hi Mike,
This setting would select the line that has any messages waiting
There is a CUCM parameter for "Always use Prime Line for Voicemail" which can be changed from True
to False
CUCM System > Service Parameters > Clusterwide Parameters (Device - Phone) > Always use Prime Line for Voicemail
Or on the phone Device page itself
Cheers!
Rob
Thanks, Rob.  What I'm actually looking to do is independent of voicemail.  I would like it so that if a user takes a phone off hook the extension that would be used would be an extension other than the first one.  Example on a 7965:
Button 1 - Extension 101
Button 2 - Extension 102
Button 3 - Extension 103
Button 4 - (nothing)
Button 5 - Speed Dial
Button 6 - Speed Dial
If a user goes off hook to make a call, Extension 103 would be the extension that would be used.
Mike
Mike,
That is not possible with 79XX phones, with 99XX for example you could keep the focus on the 3rd line, the issue though would be that everytime a call is taken on another line the focus shifts so even with these phones it would most likey work for you.  Sorry.
HTH,
Chris
