CUCM Outlook Click to Dial
johnsnave1
Are there any applications available to perform click to dial from outlook telephone numbers using integration with CUCM?
Thanks, John.
Jaime Valencia
You would need to use Jabber to get click to dial
java
if this helps, please rate
Many thanks Jamie. Do you know of any 3rd party applications for this?
Hi Jaime,
A quick questions if i want to to use jabber to get click to dial from outlook. What sort of config / integration required to achieved that ?
Thanks a million in advance !!
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/11_8/cjab_b_feature-configuration-cisco-jabber118/cjab_b_feature-configuration-cisco-jabber118_chapter_010.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/11_8/cjab_b_on-premises-deployment-for-cisco-jabber/cjab_b_on-premises-deployment-for-cisco-jabber_chapter_010011.html
java
