CUCM PUB is crashed
@Syed
Level 3
Level 3
Dear All,
Need urgent help.
I have 2 nodes in my CUCM cluster (PUB & SUB) and PUB is crashed due to power outage, and the problem is I have lost backup of PUB node also.
I have rebuild publisher node with all the previous IP settings and I can login to it.
Can I restore the PUB using SUB backup which 6 months old from now, will I be able to bring it back to normal.
Referred the below document and understood that it can be doable from subsequent node’s backup.
Restore the First Node Only
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/drs/10_0_1/CUCM_BK_D220A91D_00_disaster-recovery-system-cucm-100/CUCM_BK_D220A91D_00_disaster-recovery-system-cucm-100_chapter_011.html
Can someone guide me as to how I can fix this issue, please?
Awaiting for your valuable support.
Rajan
Hi Syed,
Please follow the procedure mentioned in the below document to restore pub from Sub database:
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/116946-technote-product-00.html
Rajan
Pls rate all helpful posts by clicking the stars below
5 Replies 5
Rajan
Hi Syed,
Rajan
Adding on to Rajan's post, the procedure is a bit tricky and the feature is introduced from CUCM Version 8.6. The major thing you need to watch out for is that replication does not kick in until the process is done, otherwise the PUB's blank database will be replicated to the SUB's and it's DB would be wiped, although you have a backup its old and there might have been a lot of changes on the present config. I'd suggest opening a TAC case, so they can help you out the procedure. Alternatively there is a procedure to restore the SUB's DB to the PUB which TAC can do but the success rate for it is very low so the first procedure would be your best bet.
Please rate if you find this helpful.
Aeby
Aeby
Thank you Aeby for your post and suggestion.
Cheers!
I would like to thank you Rajan from the bottom of my heart.
I followed procedure and was able to resolve this issue by myself.
Hi Syed,
Glad it helped. Cheers.
