04-03-2017 05:10 AM - edited 03-17-2019 09:58 AM
Hello Friends,
I have in my datacenter cisco cucm11 installed "1 pub and 2 subs".
recently we needed to make such a change that required we shutdown every server on these servers one after another and perform such a job.
I have done it so far for both subscribers BUT: the only remained server in the pub with callmanager and database management which we really need to have the CDR file with no data loss.
when we take down the pub, will that affect the contents of the CDR file and the pub had the database management service up.
will all call details running over the subs will be synced with the pub database when it comes up again which means CDR file intact and not calls logs loss?
Thank you all.
Solved! Go to Solution.
04-03-2017 06:09 AM
Hi Mohammad,
You can find the answer to your query in the following post
https://supportforums.cisco.com/discussion/12472171/if-cucm-publisher-down-does-cdr-still-active-subscriber
Manish
04-03-2017 06:09 AM
Hi Mohammad,
Manish
04-03-2017 07:09 AM
Thank you so much, answer was crystal clear.
