CUCM Pubisher v6, subscriber v7
iantra123
Level 3
Level 3
Is this possible ?
My CUCM Publisher use version 6 and the subscriber is version 7
Or my publisher is v6.0.1 and subscriber is V6.0.2
best regards,
Antra
Jaime Valencia
No, all servers in the cluster must run the EXACT same version.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
i've lost my CUCM 6.0.1.200-3 disk
thank you
Rob Huffman
Hi Antra,
What version of CUCM "build" DVD's do you have?
Let's say you have the 6.0(2) DVD's....you would normally upgrade the
Publisher to the exact same version as the version you have available. Once
the upgrade has been completed on the Pub then the Sub can be added using
these same "build" DVD's. Make sense
Cheers!
Rob
