IP Telephony and Phones
watch here Journey banner_2
Labels
We are trying to setup a call forward no answeron our call manager - version 7.1(3). I would like both internal and external calls to this 4 digit Directory number to then be forwarded to and external number.  The reasoning behind this is we acquired...
lukeprimm by Level 1
  • 488 Views
  • 2 replies
Hi Guys,    We are going to change the IP address of CCM 6.1. The list of related devices is as follows:             Cisco Call Manager 6.1 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; ...
I am adding a dial peer for a new DID to route to ICM.  The dial peer is configured like the rest of the dial peers to ICM, but the calls continue to route to CUCM instead.  I added the extension on a test phone to verify the digits are coming in cor...
Hi all,I am trying to troubleshoot an intermittent voice issue using debug isdn q931, on a Cisco 2811 with an isdn pri. I am trying to decode the last two digits in : /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; ...
ken.vance by Level 1
  • 3427 Views
  • 7 replies
I ran ServerUpdatesWizard-v.3.0.13-02-2011.exe then ran CiscoUnityConnection1.2.1-LE24ports and got the error below; Must fix: This version of Cisco Unity Connection requires Server Updates Wizard (SUW) version 1.0.1.0 or later. The current version i...
I am currently running CUCM version 6.1.5.13033-1. I have two Cisco 7960 phones, phone A and phone B.I have a call forward all on phone A to point to phone B. The call forwarding works fine. If phone B doesn't answer the call, the call goes to phone ...
rferullo by Level 1
  • 769 Views
  • 3 replies
