CUCM Question
Hi all,
I would like to know if there is some way to strip first digits when dialing. I mean, I need that when from a phone somebody dials 3422XXX the 342 is stripped so the call forwards to 2XXX that actually is the numbering plan in this CUCM.
Thanks in advance.
Gordon Ross
Level 9
Level 9
A translation pattern is your friend here.
CCMAdmin -> Call Routing -> Translation Pattern -> Add new
For your example, put the pattern as 342.2XXX
Set your pattern & CSS as necessary.
Make sure "Route Option" is set to "Route this pattern"
At the bottom in the section "Called Party Transformation", under "Discard Digits" select "PreDot"
Click save, and job done.
GTG
Please rate all helpful posts.
Gordon Ross
Level 9
Level 9
GTG
Wow men!
You're a real beast. I've been dealing with this from yesterday. Thank you very much Gordon.
