02-22-2019 04:33 AM
Hi everyone,
I am familiar with CME and would like to understand the equivalent of dial-peers in CUCM. I trying to connect a CME to a CUCM through their dial-peers. where are dial-peers configured in CUCM?Am new to CUCM and guides or links to this issue will be appreciated.
Thanks!
Solved! Go to Solution.
02-22-2019 06:21 AM
You want to do some reading on this:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/dialplan.html
02-22-2019 05:21 AM
Hello Isaac,
You may read the following document for interconnection of CUCM with CME:
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-voice/922-cisco-voice-cucm-cme-h323.html
Generally speaking, you will need to create connetivity (H323 or SIP trunk) between the 2 systems and then create route-patterns, which are the equivalent of the dial-peers on the CME.
You will find various posts at Community concerning this subject.
Hope this helps,
George
02-22-2019 06:21 AM
