CUCM Sends 404 for incoming call via SIP trunk
jintoalakkalk1
Hello All,
I have an issue with a SIP trunk, The call manager is sending 404 not found message after it sent trying message, below is the setup. Kindly help me to understand why CUCM is not able to decode and send the call to the DN 5112. 5112 is the number our SIP provider is delivering.
SIP Server 10.0.0.4 ----------> 10.0.0.153 (IP address in the router where NAT enabled)------------->172.25.225.11 (CUCM).
INVITE From SIP Server to CUCM
14584742.001 |17:14:46.429 |AppInfo  |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 1160 from 10.0.0.4:[5060]:
[14372617,NET]
INVITE sip:5112@10.0.0.153:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.0.0.4:5060;branch=z9hG4bKs3uc2t20dgj04lkn51s1.1
From: <sip:914467491300@97.56.30.7:51088;user=phone>;tag=127.0.0.1+1+a5380157+652ceee3
To: <sip:5112@97.208.31.204:5060;user=phone>
CSeq: 818076443 INVITE
Expires: 180
Min-SE: 3600
Session-Expires: 3600
Supported: replaces, timer
Content-Length: 313
Request-Disposition: fork, sequential
Allow: INVITE, BYE, REGISTER, ACK, OPTIONS, CANCEL, SUBSCRIBE, NOTIFY, PRACK, INFO, REFER, UPDATE
Call-ID: 9AB0E358-1FFEC2pzsxRAnf9OsjW3of1wRXuUYiBxisHiIwiB6zBTeY79UsAJ92FonzIYhJx1BEJKAr
P-Asserted-Identity: <sip:914467491300@97.56.30.7;user=phone>
Privacy: none
Max-Forwards: 66
Contact: <sip:914467491300@10.0.0.4:5060;transport=udp>
Content-Type: application/sdp
User-Agent: Alcatel-Lucent 5020 MGC-8 8.1.0.11.SP1.1
v=0
o=root 2085757204 2085757204 IN IP4 10.0.0.4
s=session
c=IN IP4 10.0.0.4
t=0 0
m=audio 34732 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
TRYING CUCM to SIP server
14584746.001 |17:14:46.431 |AppInfo  |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 10.0.0.4:[5060]:
[14372618,NET]
SIP/2.0 100 Trying
Date: Mon, 08 Jun 2015 11:44:46 GMT
Allow-Events: presence
Content-Length: 0
NOT FOUND CUCM to SIP server
14584775.001 |17:14:46.436 |AppInfo  |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 10.0.0.4:[5060]:
[14372619,NET]
SIP/2.0 404 Not Found
To: <sip:5112@97.208.31.204:5060;user=phone>;tag=4013311~b8eb621a-bc9d-4a8c-9274-855b9682f601-72288869
Reason: Q.850;cause=1
Content-Length: 0
10 Replies 10
the Cause code 1 states either the number is  unallocated/unassigned or number does not exist.
Please check the significant digits field on the sip trunk it should be set to >=4, or try changing it to All.
Also make sure the "Calling Search Space" in SIP trunk matches the 5112 device CSS.
-Venkatesh
Hi Venakatesh,
I set the significant digits to 4 and made sure that the CSS of the SIP trunk have the partition of 5112. Also tried assigning 5112 device CSS but its not working.
Thanks!
Jinto.
Ritesh Desai
Hi folks,
Am facing similar issue. In my case, I have 10 digits and FAC enabled.
Did you guys manage to solve the issue?
regards,
Ritesh Desai
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
Hi Ritesh,
Can you please share more details? Original issue reported is about call rejection during inbound call, what you're mentioning with respect to FAC shouldn't have any interaction as FAC is only applicable for outbound calls.
- Vivek
Dear Vivek,
Thanks for revert. My problem got resolved.
regards,
Ritesh Desai.
Thanks Ritesh for updating us.
- Vivek
Thanks for sharing.
- Vivek
Ritesh, can you please share how did the problem get resolved? I am facing a similar issue.
taha.bilal,
Can you please explain more in detail. SIP 404 means system did not find what it's looking for. OR else you can raise new thread/discussion.
regards,
Ritesh Desai.
