06-17-2015 09:22 AM - edited 03-17-2019 03:23 AM
Am trying to connect two CUCM clusters using two CUBEs. Any one with document on how to Configure this. Anything to lookout for?
06-17-2015 09:39 AM
Hi Chikona55,
After you active the CUBE services you will only work with voip dial peer in each CUBE.
Exemple: voice-card 0 dspfarm dsp services dspfarm ! ! ! voice service voip ip address trusted list ipv4 10.191.0.0 255.255.254.0 address-hiding mode border-element allow-connections sip to sip redirect ip2ip fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none sip header-passing error-passthru no update-callerid early-offer forced history-info midcall-signaling passthru ! voice class codec 1 codec preference 1 g729r8 ! voice class sip-profiles 1 request REINVITE sdp-header Audio-Attribute modify "inactive" "sendrecv" request ACK sdp-header Audio-Attribute modify "sendonly" "sendrecv" response 200 sdp-header Audio-Attribute modify "sendonly" "sendrecv" ! ! dial-peer voice 81 voip description -------------[dialplan-to-CCM-01] preference 3 destination-pattern 8... session protocol sipv2 session target ipv4:10.X.X.Z incoming called-number .T voice-class codec 1 dtmf-relay rtp-nte fax-relay ecm disable no fax-relay sg3-to-g3 fax protocol pass-through g711ulaw ! dial-peer voice 82 voip description -------------[dialplan-to-CCM-02] preference 2 destination-pattern 8... session protocol sipv2 session target ipv4:10.Y.Y.Z incoming called-number .T voice-class codec 1 dtmf-relay rtp-nte fax-relay ecm disable no fax-relay sg3-to-g3 fax protocol pass-through g711ulaw ! ! If you have a different PBX ! dial-peer voice 62 voip description -------------[Outgoing-Mx-One] translation-profile outgoing MX-ONE preference 1 destination-pattern 62.... session protocol sipv2 session target ipv4:10.X.X.C voice-class codec 1 dtmf-relay rtp-nte fax-relay ecm disable no fax-relay sg3-to-g3 fax protocol pass-through g711ulaw ! !
Best regards,
Daniel Sobrinho
06-17-2015 02:08 PM
test
06-17-2015 02:28 PM
Apologies,
Unknowingly it got pasted and now it does not allow me to delete / remove / edit it.
06-17-2015 10:31 AM
CUBEs do not register with CUCM, so nothing much to having dial-peers pointing to each cluster and corresponding trunks on the CUCMs.
Are the CUBEs in the same data center and you want HSRP redundancy? Or are these independent CUBEs pointing to separate SIP trunks?
06-17-2015 01:55 PM
The CUBEs will be connected over WAN, No HSRP redundancy. SIP trunk associated with the site CUCM pointing to the site CUBE.
06-18-2015 05:39 AM
Then you treat them separately, configure identically (with different IP addresses, etc) and in CUCM for outbound dialing add SIP trunks to appropriate route groups/route lists.
06-18-2015 05:45 AM
I guess I do not understand your question completely, so please let me know if I am off a bit.
Just adding to what Chris said:
Whether it is one CUBE which is being used by the CCMs to talk to each other or 2, fundamentally it remains the same configuration, nothing really changes per say.
eg
CUCM Cluster A <== SIP Trunk===> CUBE <<<====WAN====>>>> CUBE <==SIPTrnk===> CUCM Cluster B
06-18-2015 09:49 AM
Yes ,
CUCM Cluster A <== SIP Trunk===> CUBE <<<====WAN====>>>> CUBE <==SIPTrnk===> CUCM Cluster B -
