CUCM SIP Trunk full
Essam Butt
I have a question regarding SIP Trunks and if they are full. I understand the behaviour is that the call fails, but what other options do we have?
Can we overflow the calls to another SIP Trunk or play a message and then drop the call?
Any ideas?
6 Replies 6
Flo.Matalis
Hi, to which scenario are you referring as full? and is it incoming or outgoing calls?
I meant simultaneous calls through the trunk. Let's say our SIP Trunk can only handle 50 concurrent calls, what else can we do with the next call? What are our options here other than just declining the call? Can we play a message to the caller?
It's mostly for incoming.
I assume you are referring the  TRUNK between your CUBE and Service Provider. Based on the Router model CUBE can Have more than 50 sessions. if you wana  have more call, subscribe more session with your ISP.
https://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/data-sheet-c78-729692.html
CUBE Platform Support
Router platform
Minimum memory requirement
Maximum trunk sessions
Maximum sustainable call setup rate (Calls per second)
Cisco 1100 ISR1
Default
500
Cisco 4321 ISR
4 GB
500
Cisco 4331 ISR
4 GB
1000
Cisco 4351 ISR
4 GB
2000
13
Cisco 4431 ISR
8 GB
3000
15
Cisco 4451-X ISR
8 GB
6000
40
Cisco 4461 ISR
8 GB
10,000
55
C8200L-1N-4T
4GB
1500
9
C8200-1N-4T
8GB
2500
14
C8300-1N1S-6T
8GB
7000
40
C8300-1N1S-4T2X
8GB
8000
45
C8300-2N2S-6T
8GB
7500
42
C8300-2N2S-4T2X
16GB
10,000
55
Cisco CSR 1000V /C8000V 1vCPU2
4 GB
1000
Cisco CSR 1000V /C8000V 2vCPU2
4 GB
3000
20
Cisco CSR 1000V /C8000V 4vCPU2
8 GB
6000
30
Cisco ASR 1001-X
16 GB
12,000
50
Cisco ASR 1002-X
16 GB
14,000
55
Cisco ASR 1006-X with
RP3 and ESP100/ESP100X
16 GB
16,000
65
Cisco ASR 1004 /ASR 1006 /
ASR 1006-X with RP2 and ESP40
16 GB
16,000
70
Response Signature
Hi ,
Thanks for your reply. Yes increasing the CUBE sessions is an option but I was thinking more on the configuration side of CUCM/CUBE. Instead of abruptly ending the call, can we play a message or overflow it to another Trunk?
Just another question, SIP Trunks configured on CUCM to CUBE, do they have any limits? like max number of sessions/channels?
Playing a message, AFAIK not possible. Busy  tone is what I have commonly seen.
You can subscribe another trunk and have CUBE HA. refer the Cube configuration/Design Guides.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-cube-high-availability-ISR4K.html
Just another question, SIP Trunks configured on CUCM to CUBE, do they have any limits? like max number of sessions/channels? Have look on similar thread.
https://community.cisco.com/t5/ip-telephony-and-phones/sip-trunk-capacity/td-p/1517254
Response Signature
No there is no specific max session on the trunk between CM and your SBC (Cube). It would although adhere to the set limits that you would have defined in the IOS configuration. Or you could use the call admissions control mechanism that is in CM with locations.
On your question, it would depend on the direction of the call. Outbound you can control the path with configuration in CM to select where to send the call to a secondary destination if it gets denied by the primary destination. For inbound it would be up to your service provider to dictate what happens to the calls if it gets denied by the primary destination.
Response Signature
