CUCM SIP trunk usage (live active calls)
Rémi
Hello all,
Is there a way to see how many calls pass through a specific CUCM SIP trunk link ?
Rémi
jferris1979
You can view a graph of active calls on a SIP trunk in RTMT.  Login to RTMT then navigate to system and performance.  Open the cucm node your SIP trunk is registered to and then Cisco SIP.  Open Cisco SIP and you'll see a number of options, one of them being active calls.  Click on active calls and another box will open listing your SIP trunks.  Select the trunk you want to view and the graph will appear showing the active call count.  I hope that helps.
James
jferris1979
James
Thanks for your help James !
Thank you so much for that, very helpful.
To clarify for anyone else who is slow like me and was looking for "System and Performance" as a single menu in the RTMT, it isn't. It is located under the 'System' tab -> 'Performance' (which is under the 'Performance' header on the left panel) -> the rest of the directions were straight forward after that.
