Showing results forĀ
Search instead forĀ
Did you mean:Ā
CUCM_TO_CUBE_ITSP Provider - SIP/2.0 404 Not Found
ciscoMFNAO
Hi all,
We are configuring a new SIP Trunk to our new ITSP . Topology looks like:
CUCM---SIP TRUNK - CUBE - SIP TRUNK - ITSP
Calls are being dropped but we can ping ITSP next hop equipment and SIP Servers configured in Dial-peers. Debug shows the error SIP/2.0 404 Not Found.
Any ideas what can be causing this issue. Please note CUBE show run and debugs.
For testing We called from 9670 phone extension to 0917775245 PSTN Number
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.02.04 19:25:45 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 6218 bytes
! Last configuration change at 17:27:18 UTC Sun Feb 4 2018 by cisco
! NVRAM config last updated at 17:11:31 UTC Sun Feb 4 2018 by cisco
version 15.1
hostname JPTLDAMAN-RTSIP-01
boot-start-marker
boot-end-marker
enable secret 4Y
no aaa new-model
no ipv6 cef
ip source-route
ip cef
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 ip address trusted list
  ipv4 172.29.8.46
  ipv4 0.0.0.0
  ipv4 10.130.2.166
  ipv4 10.130.2.165
 allow-connections h323 to sip
allow-connections sip to h323
 allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
 rel1xx supported "1XX"
  min-se 90 session-expires 300
voice class codec 1
codec preference 1 g711alaw
 codec preference 2 g711ulaw
codec preference 3 g722-64
 codec preference 4 g729r8
codec preference 5 g729br8
 codec preference 6 g722-56
voice class sip-profiles 1
request INVITE sip-header Min-SE modify "90" "1800"
 request REINVITE sip-header Min-SE modify "90" "1800"
request INVITE sip-header Session-Expires modify "300" "1800"
 request REINVITE sip-header Session-Expires modify "300" "1800"
voice class sip-profiles 2
request INVITE sip-header Min-SE modify "1800" "90"
 request REINVITE sip-header Min-SE modify "1800" "90"
request INVITE sip-header Session-Expires modify "1800" "300"
 request REINVITE sip-header Session-Expires modify "1800" "300"
voice class sip-profiles 300
request ANY sdp-header Audio-Attribute modify "inactive" "sendrecv"
 request ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
request ANY sdp-header Audio-Attribute modify "recvonly" "sendrecv"
 response ANY sdp-header Audio-Attribute modify "inactive" "sendrecv"
response ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
 response ANY sdp-header Audio-Attribute modify "recvonly" "sendrecv"
voice translation-rule 1
 rule 1 /^0/ //
rule 2 /^000/ /00/
voice translation-rule 2
 rule 1 /^222\(......\)/ /0222\1/
rule 2 /^9\(........\)/ /09\1/
 rule 3 /^244222\(......\)$/ /0222\1/
rule 4 /^2449\(........\)$/ /09\1/
 rule 5 /\(^.+\)/ /000\1/
voice translation-profile LocalRule
 translate calling 2
voice translation-profile SIP-PSTN-OUT
translate called 1
license udi pid CISCO2911/K9 sn
hw-module pvdm 0/0
username cisco privilege 15 secret 4
redundancy
interface Loopback10
no ip address
interface Embedded-Service-Engine0/0
 no ip address
shutdown
interface GigabitEthernet0/0
 no ip address
shutdown
 duplex auto
speed auto
interface GigabitEthernet0/1
 description RTACC08-00-G0/9
ip address 172.29.8.146 255.255.255.0
 no ip redirects
no ip unreachables
 no ip proxy-arp
duplex auto
 speed auto
no mop enabled
interface GigabitEthernet0/2
 description SIP To Angola Telecom
ip address 10.130.2.166 255.255.255.252
 no ip redirects
no ip unreachables
 no ip proxy-arp
duplex auto
 speed auto
no mop enabled
interface FastEthernet0/0/0
 no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
 no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.29.8.1
ip route 0.0.0.0 0.0.0.0 10.130.2.165
ip route 10.0.0.0 255.0.0.0 172.29.8.1 name LAN_172
ip route 66.110.114.0 255.255.255.0 10.130.2.165
ip route 172.0.0.0 255.0.0.0 172.29.8.1 name LAN_172
ip route 192.0.0.0 255.0.0.0 172.29.8.1 name LAN_172
logging trap debugging
control-plane
mgcp profile default
dial-peer voice 1 voip
redirect ip2ip
 no modem passthrough
session protocol sipv2
 incoming called-number .
voice-class codec 1
 dtmf-relay sip-notify rtp-nte
fax-relay ecm disable
 no fax-relay sg3-to-g3
fax rate 14400
 no vad
dial-peer voice 40 voip
translation-profile outgoing LocalRule
 destination-pattern 2T
session target ipv4:172.29.8.46
 voice-class codec 1
 fax rate 14400
no vad
dial-peer voice 10 voip
 translation-profile outgoing SIP-PSTN-OUT
destination-pattern 02........
 redirect ip2ip
 session target ipv4:66.110.114.133
voice-class codec 1
 fax rate 14400
no vad
dial-peer voice 20 voip
destination-pattern 000T
 redirect ip2ip
voice-class codec 1
dial-peer voice 50 voip
description #Emergency Calls#
 destination-pattern 01..
voice-class codec 1
dial-peer voice 51 voip
 destination-pattern 1..
voice-class codec 1
dial-peer voice 15 voip
 destination-pattern ^9........
redirect ip2ip
codec g711alaw
gateway
timer receive-rtp 1200
sip-ua
gatekeeper
 shutdown
line con 0
exec-timeout 9 0
 privilege level 0
line aux 0
 exec-timeout 9 0
privilege level 0
line 2
no activation-character
 no exec
transport preferred none
 transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 60 0
privilege level 15
 password cisco
login local
 transport input all
line vty 5 15
 exec-timeout 9 0
privilege level 15
 login
transport input all
scheduler allocate 20000 1000
end
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
JPTLDAMAN-RTSIP-01#
Chris Deren
What country is this in?
The call is going out as 917775245, is this correct dial string? 404 means the number is incorrect, so perhaps you are sending the incorrect digits to the telco provider.
