02-16-2015 10:36 PM - edited 03-17-2019 02:00 AM
Dears,
I have a sip trunk to avaya systems, calls flow from cisco to avaya is perfect no encryption, when avaya ipphone try to initiate a encrypted call to cisco ip phone the call fails becz cisco ip phone do not about encryption,
i want to know is it doable means in other words i want to say without security tokens is it cisco ip phone can accept encrypted calls.
02-17-2015 02:24 AM
Can you provide some more details like:
cucm version
IP phone model and firmware involved
How do you know that the call is failing because of encryption? Does a normal call without encryption work?
Manish
02-17-2015 02:52 AM
Dear Manish
Thanks for the reply
ver 8.5
7945
Avaya ip phones initiate a encrypted call internally between avaya ip phones , when the avaya ip phone disables security profile on the phone the call gets established to cisco ip phone.
02-17-2015 07:37 AM
Apparently someone else has the exact same problem as you do, and has already posted the same:
https://supportforums.cisco.com/discussion/12427761/cucm-85-sip-trunk
02-17-2015 10:19 AM
Dear Jaime,
Both are waiting for the answer, is it doable or no,so that atleast we can proceed to buy security tokens.
thanks
02-17-2015 12:20 PM
I don't think that's doable with security, all of the guides in the interoperability portal are regular SIP trunks or PRI integrations.
I don't see how we could exchange security information with other vendor to do what you're asking.
