CUCM upgrade from 6.1.2 to 8.5
acharyr123
Level 3
Level 3
I would like to upgrade CUCM from 6.1.2 to 8.5...I got the licenses from cisco.Can i directly upgrade the same? What is the upgrade process, can someone help me in this plz..
Rob Huffman
Hi Partha,
There is no "Direct" path from CUCM 6.1(2) to 8.5(1)
Table 4     Export Restricted Supported Cisco Unified Communications Manager Upgrades for Release 8.5(x)
8.5(1)SU1
8.5(1)
System Version
8.5.1.11900-21
8.5.1.10000-26
Release Date
Feb 9 2011
Nov 15 2010
Standard Support
Direct upgrade:
8.5(1), 8.0(3a)SU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(5b)SU4(restricted), 7.1(5b)SU3(restricted), 7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4)
Direct upgrade:
Direct upgrade using DMA:
none
Note Refer to the Notes about Engineering Specials (ESs), Service Updates (SUs), and Windows Service Release (SR) Upgrades concerning upgrades from ESs.
So, you would need to move to 6.1(4) as a first step. You will also want to look into
whether or not your current servers are supported in 8.5(1). Here is the master list for
server support;
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Cheers!
Rob
Rob Huffman
Hi Partha,
8.5(1)SU1
8.5(1)
System Version
8.5.1.11900-21
8.5.1.10000-26
Release Date
Feb 9 2011
Nov 15 2010
Standard Support
Direct upgrade:
Direct upgrade:
none
server support;
Cheers!
Rob
Hi Rob,
Thanks for your prompt support....by the way, i am facing an issue with mobile voice access...can you help me in this??
MVA is configured...i do get the IVR prompt & it prompts to put the PIN, press 1 for dialing etc..but whenever i put 1 & dial the number 90553507853, the call gets dropped...any idea?? Gateway is configured in H323 mode..
Jaime Valencia
FYI this is covered in the new FAQ:
Announcement: IP Telephony FAQs and Basics - Please read before  posting!
Cisco Unified Communications Manager (CallManager) Frequently Asked  Questions
I'm  running version x.  What do I need to do to get to version y and are  there any "gotchas"?
https://supportforums.cisco.com/docs/DOC-13450#Im_running_version_x_What_do_I_need_to_do_to_get_to_version_y_and_are_there_any_gotchas
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
dsmith.tig
Rob,
Is this upgrade path supported for Business Edition on MCS7826H3 as well..?
My path needs to go from CUCMBE 6.1(2) to final deployment of CBE6K on UCS C220 (VMware 5)
I realize I have to make at least one jump. would it be best to go from 6.1(2) to 6.1(4), and then to 9.1(1). I heard somewhere it may be better to jump from 6.1(2) to 8.5(1), and then to 9.1(1).
Also will I need to perform DRS/DMA between every path upgrade,.?
This will have to support embedded Unity Connection migration as well.
Please advise...Thanks,
Doug Smith
