05-14-2011 10:33 AM - edited 03-16-2019 04:58 AM
It seems like each time I do a major version upgrade of CUCM, I spend numerous hours trying to figure out my upgrade paths. Each link I click on the cisco site seems to point me to the same few documents and I dont get my answer. I thought I would post a question to see if I can cut down on that time.
We're currently on MSC7816H3-K9-CMB1 hardware (Pub and Sub) with 160 GB drives, and I can only assume it was shipped with 2GB RAM. Our version of CUCM is 7.1.2.2199-5 and we'd like to get to version 8.5.x (whichever the newest is). I remember reading a document that expains we should be running 4GB RAM when using 8.0(3) through 8.5 when using 7816 hardware.
I figured I would need to get to 7.1.5 first, then go from there so I downloaded the following file: cmterm-devicepack7.1.5.33052-1.cop.sgn. I do this so rarely that I'm guessing this is the wrong file. Do I need the LOCALE file (English) instead?
After I get to 7.1.5, what's next? Can I skip to 8.5 or do I have to go to 8.0 first? Very confused on this process, again.
Any help would be much appreciated.
Rory Schmitz
05-14-2011 10:56 AM
Hi Rory,
You are most correct here, there is no "direct" path from 7.1(2) to 8.5(1)
Cisco Unified Communications Manager | 8.5(1)SU1 | 8.5(1) |
System Version | 8.5.1.11900-21 | 8.5.1.10000-26 |
Release Date | Feb 9 2011 | Nov 15 2010 |
Standard Support | Direct upgrade: 8.5(1), 8.0(3a)SU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(5b)SU4(restricted), 7.1(5b)SU3(restricted), 7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4) | Direct upgrade: 8.0(3a)SU2, 8.0(3a)SU1, 8.0(3a), 8.0(3), 8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), |
Direct upgrade using DMA: none | ||
Note Refer to the Notes about Engineering Specials (ESs), Service Updates (SUs), and Windows Service Release (SR) Upgrades concerning upgrades from |
So your first step should be to something like 7.1(3b)su2. Here are the paths to it;
Cisco Unified Communications Manager | 7.1(3b)SU2 | 7.1(3b)SU1 | 7.1(3b) | 7.1(3a)SU1a | 7.1(3a)SU1 | 7.1(3a) | 7.1(3) |
System Version | 7.1.3.32900-4 | 7.1.3.31900-1 | 7.1.3.30000-1 | 7.1.3.21901-1 | 7.1.3.21900-4 | 7.1.3.20000-2 | 7.1.3.10000-11 |
Release Date | Feb 18 2010 | Dec 15 2009 | Dec 15 2009 | Dec 8 2009 | Dec 1 2009 | Nov 4 2009 | Sep 22 2009 |
Standard Support | Direct upgrade: 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3) | Direct upgrade: 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3) | Direct upgrade: 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1, 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3) | Direct upgrade: 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3) | Direct upgrade: 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3) | Direct upgrade: 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1 , 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3) | Direct upgrade: 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3) |
Direct upgrade using DMA: none | Direct upgrade using DMA: none | Direct upgrade using DMA: 4.3(2), 4.2(3), 4.1(3) | Direct upgrade using DMA: none | Direct upgrade using DMA: none | Direct upgrade using DMA: 4.3(2), 4.2(3), 4.1(3) | Direct upgrade using DMA: 4.3(2), 4.2(3), 4.1(3) | |
Note Refer to the Notes about Engineering Specials (ESs), Service Updates (SUs), and Windows Service Release (SR) Upgrades concerning upgrades from ESs. |
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp259882
You would want to download these sets of .iso files;
Installation Instructions
NoteApply this Service Update to all of your Cisco Unified Communications Manager servers, beginning with the publisher server and TFTP server.
Refer to the “Software Upgrades” section of the Cisco Unified Operating System Administration Guide for detailed instructions on “Software Upgrade and Installation.”
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch7.html
NoteBecause the 7.1.3.32900-4 build is a nonbootable ISO, it proves useful only for upgrades. You cannot use it for new installations.
Because of its size, the UCSInstall.iso file, UCSInstall_UCOS_7.1.3.32900-4.sgn.iso, comprises two parts:
•UCSInstall_UCOS_7.1.3.32900-4.sgn.iso_part1of2
•UCSInstall_UCOS_7.1.3.32900-4.sgn.iso_part2of2
Prior to installation these two parts must be combined into a single file using the procedures documented below.
Step 1From www.cisco.com, download the two UCSInstall files.
Step 2Combine the two files using one of the following methods:
Linux
If you have a Unix/Linux system, the two parts can be combined with this command:
cat UCSInstall_UCOS_7.1.3.32900-4.sgn.iso_part1of2 UCSInstall_UCOS_7.1.3.32900-4.sgn.iso_part2of2 > UCSInstall_UCOS_7.1.3.32900-4.sgn.iso
Windows
If you have a Windows system, cut and paste the following command from this document into the command prompt (cmd.exe) to combine the two parts:
COPY /B UCSInstall_UCOS_7.1.3.32900-4.sgn.iso_part1of2+UCSInstall_UCOS_7.1.3.32900-4.sgn.iso_part2of2 UCSInstall_UCOS_7.1.3.32900-4.sgn.iso
Step 3Use an md5sum utility to verify that the MD5 sum of the final file is correct.
The MD5 for this download is: d450666dafbc8f01c111ed0158f748fb
Step 4Install the Service Update file: UCSInstall_UCOS_7.1.3.32900-4.sgn.iso
http://www.cisco.com/web/software/282074295/31799/cucm-readme-713bsu2.pdf
NoteApply this SU to all of your Cisco Unified Communications Manager servers, beginning with the publisher server and TFTP server.
Refer to the “Software Upgrades” section of the Cisco Unified Communications Operating System Administration Guide, Release 8.5(1) for detailed information about doing this upgrade:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/8_5_1/cucos/iptpch7.html
NoteBecause the 8.5.1.11900-21 build is a non-bootable ISO, it proves useful only for upgrades. You cannot use it for new installations.
Release 8.5(1) is available in both restricted (which is the release type that has always been available from Cisco) and unrestricted versions of software to comply with import / export restrictions to various countries. The unrestricted version is available in limited markets. Please refer to the 8.5(1) Release Notes referenced above for a more detailed description.
The file names and MD5 values you will use for this upgrade are:
•UCSInstall_UCOS_8.5.1.11900-21.sgn.iso_part1of3
•UCSInstall_UCOS_8.5.1.11900-21.sgn.iso_part2of3
•UCSInstall_UCOS_8.5.1.11900-21.sgn.iso_part3of3
The MD5 for the Restricted combined download is: 997f2f19b6fb94b32d172856ac63087d
Or for the Unrestricted version:
•UCSInstall_UCOS_UNRST_8.5.1.11900-21.sgn.iso_part1of3
•UCSInstall_UCOS_UNRST_8.5.1.11900-21.sgn.iso_part2of3
•UCSInstall_UCOS_UNRST_8.5.1.11900-21.sgn.iso_part3of3
The MD5 for the Unrestricted combined download is: 849f7ce8a2ab12ecf560747f6af98275
http://www.cisco.com/web/software/282074295/44508/cucm-readme-851su1-Rev2.pdf
This is the "master" list for Server support (which does show support for the 7816H3);
Supported Cisco Unified Communications Manager Releases by Server
Cheers!
Rob
05-16-2011 12:27 PM
Hi Rob,
Thank you for the information and clarification! Very helpful. At what point would I need to add my licensing? I'm under the impression I would need to move from 7.x to 8.x. Does it allow for a grace period after upgrade, or should I obtain the license files beforehand?
We will start planning a rollout within the next week or so. Thank you very much.
Rory Schmitz
