cucm version 11 server spec
johnsnave1
Hi, I have a customer who has HP DL380 G9 servers and wants to run UCM/CUC version 11 on ESXi6. Is there a doc with minimum CPU/memory requirements or supported servers. I have been searching but cannot find.
Many Thanks, John.
2 Accepted Solutions
Rajan
Hi John,
YOu can get the required details in the below link:
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unified_Communications_Manager_(CUCM)#Version_11.x
Rajan
Deepak Rawat
Since you want to install UCNM/CUC on a HP server and not on Cisco UCS server, hence that will fall under the category of Third-Party Server Specs-based. It is absolutely ok to go ahead with the installation as long as your HP server meet the hardware requirements mentioned in below document as per Third-Party Server Specs-based :
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware#.22Can_I_use_this_server.3F.22
Deepak
Rajan
Hi John,
Rajan
Many thanks - much appreciated!!
Deepak Rawat
Deepak
