10-21-2013 02:49 AM - edited 03-16-2019 07:59 PM
Hello ladies and Gentlemen,
I Had a call manager running software version (Engineering Special 7.0.2.21015-1) and I do not have the source for this ES and I could not find it any more on Cisco Downloads like it is obsolete (correct for me if I am wrong) is there is a way to order this patch specifically one more question could I take a backup from this version (7.0.2.21015-1) and restore the backup on Version (7.0.2.20000-5) My researches guide me that is can not be accomplisied (Is that confirmed) So what shall I shall I do to back up my system with a source for my runnnig software version DVD to use it in case of DR and to restore my Backup to it.
Solved! Go to Solution.
10-21-2013 03:10 AM
Hi Karim,
you need to have exactly same CUCM version while doing the restore.
This ES might have been provided to you by TAC as a workaround to issue which u might have been facing earlier.
Two ES available are not going to help you.
Cisco Unified Communications Manager 7.0(2.21010-2) Engineering Special and 7.0(1.21007.1) Engineering Special |
What u can do is open a TAC case and ask them to publish ES again?
regds,
aman
10-21-2013 03:10 AM
Hi Karim,
regds,
aman
10-21-2013 03:13 AM
Thanks Aman thats I thought too.
10-21-2013 03:32 AM
Hi Karim,
thanks for the rating.
regds,
aman
