HiMaking a backup in a CCM9 always stop at the same point, in TFTP, i have triyed to restart TFTP in both server but still fails, does anybody knows what´s the problem?thanks!
Hi,i have CME 8.6 and have configured a local directory with external numbers. But if i dial from a number which is in the local directory from outside i only see the number and not the configured name in the Local directory?What did i wrong?RegardsJ...
Hi, looking for recommendations/suggestions for a new config with BE6K (v 9.1), using Jabber/Presence and UCCX agent desktop. Customer is looking for presence information of all users in organization, both in and out of the Contact Center. Cannot s...
Hi all,i have some problem with my cisco 7940/60 cisco 7940/60 with 8.1(2) firmware would not register to CM 8.6(2)SU3. the problem was the phone is configuring IP and get DHCP server is 255.255.255.255. i tried to upgrade firmware to be 8.1(2)_SR2 a...
Hello.I have the next problem.Our company has a topology:IP Phones --- CUCM 8.6(10.1.1.4) ---SIP trunk --- (10.1.1.254)CUBE ---- SIP Provider.Our company decided to migrate all phones to CUCM 9.0. So I have temporary working separate CUCM 9.0 server....
Hi,I am unable to create a backup device, the error is "update failed unable to access sftp server. please verify sftp permissions". The cucm version is 8.5.1.13900-5, I am able to sftp to the machine using psftp and create new files to the root fold...
Hi,i am planning for the CUCM upgrade from 7.1.5 to 8.6.2, after looking at the software compatibility matrix, i m still not able to find out the correct version for some applications.Will CUCM 8.6.2 supports below version of CUC and CUPS:Unity Conne...
Hi All,Please i need your support to integrate Unity Connection with Exchange 2010.Below are things which are already been done.1.Integration with CUCM.2.Integration with LDAP.Currently i dont want to utilize the single Inbox feature first i need to ...
Hello Experts,I need to master myself in VOIP troubleshoooting in every aspect of it.Can some share me a document which can shape my skills and turn my life .Thanks.SAIF
Hi, I have a customer using cucm 6.1. His call manager forwards calls when no answer to mobile phone. It's working internally meaning calling from one IP phone to another with no answer call will be forwarded to mobile phone, but when calling from mo...
Hi Team,I am using a CUPS Ver 8.0 integrated with a CUCM 8.0Recently we had a problem, and I was asked (by management) to get the chat history of another employee from the cups server.Do you know how i can get this and also, where this cache will be ...
Dears,Kindly note that i have a problem with the backup of our CUCM, our CUCM Version is 8.6.2.23900-10 and actually this probelm appeared after a minor upgrade from 8.6(2a)SU2 to 8.6(2a)SU3.The backup always fails at TFTP component, log file attache...
Hi,we are in design phase for one customer and he is asking for the CUCM to support authentication and encryption of both signalling and payload data. Do we need to purchase tokens in this case or the system will provide that by default?note that we ...
We have a UC520 connected to an 871 at a home site via vpn. About 18 months ago this configuration worked. Not sure what caused it to go down.If the phone is brought to the office and plugged in it will come up fine. But over the vpn it will not w...
voicemail is working. MWI is not. I can see the sip notify message come in with the ccsip messages debug and I can see a call go out to the mwi dn for the phone. But the light is not turning on. Here is the configWith voip.ms the sip notify messa...
Subject | Author | Posted |
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM | ||
07-02-2025 08:49 AM | ||
07-01-2025 09:51 PM | ||
06-30-2025 02:50 AM |
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
